Cassete general com erro 0.09.
Mestreclima
- Enviou: 10 vezes
Boas , tenho uma maquina de cassete que apresenta no comando E.EE, na pesquisa de erro da 0.09 Alguém pode ajudar? Obrigado
Rochinha
Rochinha
Re: Cassete general com erro 0.09.
Marca e modelo etc.
Marca e modelo etc.
Mestreclima
- Enviou: 10 vezes
Boas Mario,
Marca FUJITSO GENERAl
Modelo - AOG25UNANL
Modelo - AOG25UNANL
Rochinha
Rochinha
Fujitsu Error and Fault Codes – Airpro can diagnose all Fujitsu Air conditioning fault and error codes.
Airpro provide the following Fujitsu Fault Error code. To protect your warranty contact Airpro with your Fujitsu error code and discuss with us your options for rectifying the issue.
Airpro service all Perth areas and can supply Fujitsu spare parts to resolve your Fujitsu error code.
Fujitsu Air Conditioner Hardwired Remote Controller System Error Codes.
When EE:EE is displayed on remote control , press “Energy Save” &
“Zone Control” buttons simultaneously for longer than 3 secs.
The error code will then be displayed on the LCD.
Code Fault
E0:00 Coms error – indoor to remote
E1:00 Coms error – indoor to outdoor
E2:00 Return air thermistor open circuit
E3:00 Return air thermistor short circuit
E4:00 Indoor coil thermistor open
E5:00 Indoor coil thermistor shorted
E6:00 Outdoor coil thermistor open
E7:00 Outdoor coil thermistor shorted
EA:00 Outdoor ambient thermistor open
Eb:00 Outdoor ambient thermistor shorted
Ec:00 Discharge pipe themistor open
Ed:00 Discharge pipe thermistor shorted
EE:00 High Pressure problem
EF:00 Discharge pipe temp. Problem – too high = short of gas
Press “Energy Save” & “Zone Control” buttons simultaneously for longer
than 3 secs to return to normal operating mode
(1) Stop the air conditioner operation.
(2) Press the master control button and the fan control button simultaneously for 2 seconds or more to start the test run
(3) Press the start/stop button to stop the test run
[SELF-DIAGNOSIS]
When the error indication E:EE is displayed, follow the following items
to perform the self-diagnosis. E:EE indicates an error has occurred.
1. REMOTE CONTROLLER DISPLAY
2) Press the set temperature buttons simultaneously for 5 seconds or more to start the self-diagnosis.
Refer to the following tables for the description of each error code
(3) Press the set temperature buttons simultaneously for 5 seconds or more to stop the self-diagnosis.
Error code = 00
Error contents = Communication error (indoor unit to remote controller)
Error code = 01
Error contents = Communication error (indoor unit to outdoor unit)
Error code = 02
Error contents = Room temperature sensor open
Error code = 03
Error contents = Room temperature sensor short-circuited
Error code = 04
Error contents = Indoor heat exchanger temperature sensor open
Error code = 05
Error contents = Indoor heat exchanger temperature sensor shortcircuited
Error code = 06
Error contents = Outdoor heat exchanger temperature sensor open
Error code = 07
Error contents = Outdoor heat exchanger temperature sensor shortcircuit
Error code = 08
Error contents = Power source connection error
Error code = 09
Error contents = Float switch operated
Error code = 0A
Error contents = Outdoor temperature sensor open
Error code = 0b
Error contents = Outdoor temperature sensor short-circuited
Error code = 0c
Error contents = Discharge pipe temperature sensor open
Error code = 0d
Error contents = Discharge pipe temperature sensor short-circuited
Error code = 0E
Error contents = Outdoor high pressure abnormal
Error code = 0F
Error contents = Discharge pipe temperature abnormal
Error code = 11
Error contents = Model abnormal
Error code = 12
Error contents = Indoor fan abnormal
Error code = 13
Error contents = Outdoor signal abnormal
Error code = 14
Error contents = Outdoor EEPROM abnormal
2. OUTDOOR UNIT LEDS
When the outdoor temperature drops, the outdoor units fans may switch
to low speed.
ERROR : HEAT & COOL MODEL (REVERSE CYCLE) ONLY
The LED lamps operate as follows according to the error contents.
These pages cover the current Inverter product range.
They also cover the ARY60U, ARY54U Single and AOY19/24F/U Multi Systems.
Models with Wireless Controllers
Trouble Shooting from the Indoor Unit
Wall Mounted Single Systems ASY, ASYA & ASYB
Includes AWYZ Nokria Models
Red Light Operation = Off
Green Light Timer = 2 Flashes
Reverse Comms Fail at Startup
Green Light Timer = 3 Flashes
Reverse Comms Fail In Use
Green Light Timer = 4 Flashes
Forward Comms Fail at Startup
Green Light Timer = 5 Flashes
Forward Comms Fail In Use
Green Light Timer = 8 Flashes
Wired Remote Control Failure
Red Light Operation = 2 Flashes
Indoor Air Sensor Fail
Indoor Pipe Sensor Fail
Red Light Operation = 3 Flashes
Green Light Timer = 2 Flashes OD
Disch Sensor Fail
Green Light Timer = 3 Flashes OD
Pipe Sensor Fail
Green Light Timer = 4 Flashes OD
Air Sensor Fail
Compressor Temp Sensor Fail
Red Light Operation = 4 Flashes
Forced Auto Switch Welded
Main Relay Welded
Power Failure
Green Light Timer = 7 Flashes
VDD Permament Stop Protection
Reverse VDD Permament Stop
Red Light Operation = 5 Flashes
Current Trip
CT Abnormal
Compressor Failure
Green Light Timer = 6 Flashes
Outdoor Fan Failure
Red Light Operation = 6 Flashes
ID Fan Motor Locked
ID Fan Motor Rotation Error
Red Light Operation = 7 Flashes
High Discharge Temperature
High Pressure
Pressure Switch Fail
Red Light Operation = 8 Flashes
Active Filter AFM Fail 1st Time
Active Filter AFM Fail 2nd Time
PFC Circuit Error
Red Light Operation = Blinking
Green Light Timer = Blinking
PCB Failure
All Other Wireless Indoor Units AUY, ABY & AWY Models
Including Multi Systems (Not J Series or VRF)
Red Light operation = On
Green Light Timer =
Yellow Light Swing =
Normal
Green Light Timer = Slow Blink
Yellow Light Swing = Slow Blink
Test
Red Light operation = Blinks
Green Light Timer = Blinks
Yellow Light Swing = Off
ID PCB Fail
Yellow Light Swing = Blinks
OD PCB Fail
Green Light Timer = 2 Pulses
OD Power Connection Failure
Green Light Timer =3 Pulses
OD Unit Pipe Sensor Fail
Green Light Timer =4 Pulses
Yellow Light Swing = Off OD
Unit Air sensor Fail
OD Unit Air sensor Short
Green Light Timer = 5 Pulses
OD Unit Disch Sensor Fail
OD Unit Disch Sensor Short
Green Light Timer = 6 Pulses
High Pressure
Green Light Timer = 7 Pulses
High Discharge or Compressor Temp
Green Light Timer = 9 Pulses
OD Unit Compressor Temp Sensor
Green Light Timer = 10 Pulses
IPM Error
Green Light Timer = 11 Pulses
CT Error
Green Light Timer = 12 Pulses
AFM Filter Error
Green Light Timer = 13 Pulses
Compressor Error
Green Light Timer = 14 Pulses
OD Fan Motor Fail
Red Light operation = 2 Pulses
Air Sensor Open
Air Sensor Closed
Red Light operation = 3 Pulses
Pipe Sensor Open
Pipe Sensor Closed
Red Light operation = 4 Pulses
Drain Problem
Red Light operation = 5 Pulses
Communication Error
OD PCB or Wiring Error
Red Light operation = 6 Pulses
Indoor Fan Failure
Wall Mounted Multi Models
Initial Display
Red = 2 Flashes
Green = Blinks
Meaning = ID Sensor Failure
Further Interrogation by Pressing Test Button on Infra Red RC
Red = Blinks
Green = 2 Flashes
ID Air Sensor
Initial Display
Red = 2 Flashes
Green = Blinks
Red = Blinks
Green = 3 Flashes
ID Pipe Sensor
Initial Display
Red = 4 Flashes
Green = Blinks
Meaning = ID Control Error
Red = Blinks
Green = 2 Flashes
Manual Auto Button Error
Initial Display
Red = 4 Flashes
Green = Blinks
Red = Blinks
Green = 4 Flashes
Power Source Failure
Initial Display
Red = 5 Flashes
Green = Blinks
Meaning = Comms Failure
Red = Blinks
Green = 2 Flashes
Reverse Comms Failure
Initial Display
Red = 5 Flashes
Green = Blinks
Red = Blinks
Green = 3 Flashes
Forward Comms Failure
Initial Display
Red = 6 Flashes
Green = Blinks
Meaning = ID Fan Failure
Red = Blinks
Green = 2 Flashes
Motor locked
Initial Display
Red = 6 Flashes
Green = Blinks
Red = Blinks
Green = 3 Flashes
Motor RPM Incorrect
Initial Display
Red = Blinks
Green = 2 Flashes
Meaning = OD Thermistor Fail
Red = 2 Flashes
Green = Blinks
OD Discharge Sensor Fail
Initial Display
Red = Blinks
Green = 2 Flashes
Further Interrogation by Pressing Test Button on Infra Red RCl
Red = 4 Flashes
Green = Blinks
OD Pipe Sensor Fail
Initial Display
Red = Blinks
Green = 2 Flashes
Red = 6 Flashes
Green = Blinks
OD Air Sensor Fail
Initial Display
Red = Blinks
Green = 2 Flashes
Red = 8 Flashes
Green = Blinks
Initial Display
Red = Blinks
Green = 2 Flashes
Red = 9 Flashes
Green = Blinks
2 Way Valve Sensor Fail
Initial Display
Red = Blinks
Green = 2 Flashes
Red = 10 Flashes
Green = Blinks
3 Way Valve Sensor Fail
Initial Display
Red = Blinks
Green = 3 Flashes
Meaning = Pressure Switch
Red = 2 Flashes
Green = Blinks
Pressure Switch
Initial Display
Red = Blinks
Green = 4 Flashes
IMeaning = D Units Incorrect
Red = 2 Flashes
Green = Blinks
Incorrect Indoor Unit Index
Initial Display
Red = Blinks
Green = 5 Flashes
Meaning = Inverter Failure
Red = 2 Flashes
Green = Blinks
IPM Failure
Initial Display
Red = Blinks
Green = 5 Flashes
Red = 5 Flashes
Green = Blinks
Compressor Failure
Indoor unit
ASYG07LMCA
ASYG09LMCA
ASYG12LMCA
Outdoor unit
AOYG07LMCA
AOYG09LMCA
AOYG12LMCA
Error = Serial communication error
Operation = 1 flash (0.5s on / 0.5s off)
Timer = 1 flash (0.5s on / 0.5s off)
Economy = Rapid flash (0.1s on / 0.1s off)
Error = Indoor unit PCB model information error
Operation = 3 flash (0.5s on / 0.5s off)
Timer = 2 flash (0.5s on / 0.5s off)
Error = Manual auto switch error
Timer = 5 flash (0.5s on / 0.5s off)
Error = Room temp. sensor error
Operation = 4 flash (0.5s on / 0.5s off)
Error = Indoor unit Heat Ex. Middle temp.sensor error
Error = Indoor unit fan motor error
Operation = 5 flash (0.5s on / 0.5s off)
Error = Indoor unit error
Timer = 15 flash (0.5s on / 0.5s off)
Error = Outdoor unit main PCB model information error or communication error
Operation = 6 flash (0.5s on / 0.5s off)
Error = Inverter error
Timer = 3 flash (0.5s on / 0.5s off)
Error = Active filter error, PFC circuit error
Timer = 4 flash (0.5s on / 0.5s off)
Error = Trip terminal L error
Error = Display PCB microcomputers communication error
Timer = 10 flash (0.5s on / 0.5s off)
Error = Discharge temp. sensor error
Operation = 7 flash (0.5s on / 0.5s off)
Error = Outdoor unit Heat Ex. liquid temp. sensor error
Error = Outdoor temp. sensor error
Error = Current sensor error
Operation = 8 flash (0.5s on / 0.5s off)
Error = Trip detection
Operation = 9 flash (0.5s on / 0.5s off)
Error = Compressor rotor position detection error
Error = 4-way valve error
Timer = 9 flash (0.5s on / 0.5s off)
Error = Discharge temp. error
Operation = 10 flash (0.5s on / 0.5s off)
Vê se serve
Code Fault
[SELF-DIAGNOSIS]
Error code = 00
Error code = 01
Error code = 02
Error code = 03
Error code = 04
Error code = 05
Error code = 06
Error code = 07
Error code = 08
Error code = 09
Error code = 0A
Error code = 0b
Error code = 0c
Error code = 0d
Error code = 0E
Error code = 0F
Error code = 11
Error code = 12
Error code = 13
Error code = 14
to low speed.
Disch Sensor Fail
Pipe Sensor Fail
Air Sensor Fail
Main Relay Welded
Power Failure
Current Trip
CT Abnormal
Compressor Failure
Outdoor Fan Failure
ID Fan Motor Locked
High Pressure
PFC Circuit Error
PCB Failure
Green Light Timer =
Normal
Test
ID PCB Fail
OD PCB Fail
High Pressure
IPM Error
CT Error
AFM Filter Error
Compressor Error
OD Fan Motor Fail
Air Sensor Open
Air Sensor Closed
Pipe Sensor Open
Pipe Sensor Closed
Drain Problem
Communication Error
Indoor Fan Failure
Initial Display
Red = 2 Flashes
Green = Blinks
Red = Blinks
Green = 2 Flashes
ID Air Sensor
Initial Display
Red = 2 Flashes
Green = Blinks
Red = Blinks
Green = 3 Flashes
ID Pipe Sensor
Initial Display
Red = 4 Flashes
Green = Blinks
Red = Blinks
Green = 2 Flashes
Initial Display
Red = 4 Flashes
Green = Blinks
Red = Blinks
Green = 4 Flashes
Initial Display
Red = 5 Flashes
Green = Blinks
Red = Blinks
Green = 2 Flashes
Initial Display
Red = 5 Flashes
Green = Blinks
Red = Blinks
Green = 3 Flashes
Initial Display
Red = 6 Flashes
Green = Blinks
Red = Blinks
Green = 2 Flashes
Motor locked
Initial Display
Red = 6 Flashes
Green = Blinks
Red = Blinks
Green = 3 Flashes
Motor RPM Incorrect
Initial Display
Red = Blinks
Green = 2 Flashes
Red = 2 Flashes
Green = Blinks
Initial Display
Red = Blinks
Green = 2 Flashes
Red = 4 Flashes
Green = Blinks
OD Pipe Sensor Fail
Initial Display
Red = Blinks
Green = 2 Flashes
Red = 6 Flashes
Green = Blinks
OD Air Sensor Fail
Initial Display
Red = Blinks
Green = 2 Flashes
Red = 8 Flashes
Green = Blinks
Initial Display
Red = Blinks
Green = 2 Flashes
Red = 9 Flashes
Green = Blinks
Initial Display
Red = Blinks
Green = 2 Flashes
Red = 10 Flashes
Green = Blinks
Initial Display
Red = Blinks
Green = 3 Flashes
Red = 2 Flashes
Green = Blinks
Pressure Switch
Initial Display
Red = Blinks
Green = 4 Flashes
Red = 2 Flashes
Green = Blinks
Initial Display
Red = Blinks
Green = 5 Flashes
Red = 2 Flashes
Green = Blinks
IPM Failure
Initial Display
Red = Blinks
Green = 5 Flashes
Red = 5 Flashes
Green = Blinks
Compressor Failure
Indoor unit
ASYG07LMCA
ASYG09LMCA
ASYG12LMCA
Outdoor unit
AOYG07LMCA
AOYG09LMCA
AOYG12LMCA
